5.0 help!!!!
Old Feb 14, 2005 | 11:26 AM
Jason8705's Avatar
Jason8705
5.0 help!!!!
OK, well...my F150 seems to have a problem when ideling. It has a 5.0 EFI and when it's ideling it stays at a constant rpm but it "jerks" whenever your at idel speed and i don't know what could cause it but i was thinkin maybe spark plugs and i changed them, had no effect so any advice would be helpful. Thanks!
Old Feb 15, 2005 | 09:33 AM
Kemicalburns's Avatar
Kemicalburns
pull codes. you could have a bad TPS or IAC valve. the timing could be off or the chain has slack causing a jump in time. what plugs did you go with and did you gap them to spec. you should also change the cap/rotor and fuel filter when doing a tune up maybe even the plug wires if they are old
