Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Replace Fuel Filter
Old Feb 14, 2005 | 09:29 AM
easttxtycoon's Avatar
easttxtycoon
Question Replace Fuel Filter
Im wanting to change my fuel filter on my 02 Escape.
Ive changed plenty of them on my old Chevy truck but just wondering
if there are any things i should consider while changing it. But it shouldnt be too hard to do hopefully. I got a FRAM fuel filter to replace the excisting 1. Is this a good brand? thanks for any feed back
Old Feb 14, 2005 | 01:37 PM
easttxtycoon
Well went ahead and changed the fuel filter wasnt hard at all just got plenty of gas on my hands.
Old Feb 14, 2005 | 05:24 PM
Blackie60's Avatar
Blackie60
I suggest you unplug the fuse for fuel pump and start engine and run for few minutes to reduce the pressure on the fuel line before you replace the filters and yes is that you may get some fuel all over. So, take time and you will do fine. Good Luck!!!
Old Mar 9, 2005 | 08:50 PM
solidpwder's Avatar
solidpwder
Do you need any special tool to unplug the lines?
Old Mar 10, 2005 | 06:03 PM
Blackie60's Avatar
Blackie60
No you do not need to have special tool, just regular tool like screwdriver to get the clip off.
Old Jun 2, 2006 | 12:36 PM
adipose's Avatar
adipose
where is the fuel filter located on a 2004 zetec. 2.0 liter /4 banger ?
Old Jun 2, 2006 | 01:05 PM
Ford43's Avatar
Ford43
Make sure you get the right clips with the new filter. I did not do this and had to end up using the funky looking clips that were on the original. Pretty easy job though not much to it.
