Steering Theory question:
If that didn't make too much sense, my current stock wheel travels X distance when I move the steering wheel Y inches. Is there something that will move the wheels 2X distance for Y inches steering wheel travel?
Thank you,
-dk9
First, a longer pitman arm will help. Where to get one, I don't know. But if the center to center distance is longer, the outer hole on the pitman will travel a further distance for a given angle change at the sector shaft.
Another way is to fashion up some kind of gear or chain drive unit into your steering shaft (from the steering wheel to the steering gear box) with a large gear turning a smaller one. I have seen these offered somewhere...I think it was either Jegs or Summit; however, the shaft size/shape/diameter is most likely different than what you have on your truck. A chain drive style one could be made relatively easily...just so long as it's done with safety in mind. (NOT A HACKJOB)
Just keep in mind that the less you have to turn the wheel for any given amount of tire angle change, the harder it's going to be to turn the steering wheel (probably negligible amount if you have power steering).
Cody
