A/C Blows Funny!
Old Feb 14, 2005 | 01:53 AM
blueovalwonder's Avatar
blueovalwonder
A/C Blows Funny!
i have a 94 f150 and i noticed that the a/c will blow from the vents when you first turn it on the then it stops blowing out of the vents, it blows out of the defrost. I found a device under the dash and pushed the lever and it blew out of the dash So I tie straped it open, but i have no defrost now Has anyone else ran across this, of so how easy is it to change, thanks.
Old Feb 14, 2005 | 01:06 PM
Lazy K's Avatar
Lazy K
The device you found under the hood sounds like a vacum servo. Is there a rubber pipe going to it? If so pull pipe off and with engine running check for vacum at tube in both vent and screen positions. If vacum present the servo is shot.
Old Feb 15, 2005 | 12:46 AM
blueovalwonder
bump..........
