HELP !!! 68 f 100
do i need a diffrent flywheel, bellhousing,
someone please give me a hand here
The 289 and 302 both had small or large depending on the vehicle it was put in.
you can see the difference between the two if you look at the gap between the
top starter bolt and block/bell surface area, the small diameter one has no gap
and the large diameter one has about an inch of space there... you also need
the matching tin divider plate for it.
hope this helps ya out.
