mustang 2 ?
As to posting in your gallery...I assume you have visited it? If not, click on the "User CP" button at the upper left of the main screen. Select "Edit Gallery". Then select "Create Gallery". Fill in all the info (some of it is required, I think).
Then, under the text screen, where it says "Browse" and has a button, click on the browse button. Navigate to where your pictures are in your computer, click on the picture you want to insert and click "Open" on your directory. The routing to that photo will appear opposite the "Browse" button. Scroll down to "Add photos" (or something like that) and it will go into your gallery. You can edit the photo to add text, descriptions, etc. The instructions are pretty good once your in the middle of it.
I would suggest adding photos one or two at a time, if you are on dialup modem. If you're on DSL or a T! (etc), go fo it. But the upload does take a while sometimes, especially when the server is pretty busy.
Post those pictures, man! Inquiring minds want to know...
Paul
