Aerostar Ford Aerostar
Stereo Question
Old Feb 13, 2005 | 03:15 PM
the inDifference's Avatar
the inDifference
Stereo Question
Hi all.
I just recieved a 1993 Aerostar that was handed down to me.
It only has AM/FM and that just won't cut it. I don't know much about stereos and such so, I was looking to buy a factory cassette or CD/cassette from eBay or something.
Now, when buying the stereo does it have to be from a 1993 Aerostar? Or can I buy one perhaps from a Mustang or Taurus of a different year? Aside from maybe needing a mounting kit, would all the hookups work?
Thanks in advance.
Old Feb 13, 2005 | 03:54 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 13, 2005 | 05:11 PM
93nighthawk's Avatar
93nighthawk
All Ford DIN size radios will work from all models from '89-'95.
You can get a junkyard/e-bay one with cassette for about $15. It does not require any additional hardware. Just make sure not to get one that say's JBL or MACH on it. Otherwise you will need the amp also.
Personally I would go aftermarket. The Ford CD head units run $100+ used. I believe around $250-$300 new from Ford. Check out www.crutchfield.com and see if there is something that tickles your fancy. 90% of the decks out there are DIN size and will fit in the current hole without any modification. Crutchfield gives you all the wiring you will need to hook it up to the stock connector plus instructions (and free telephone support.) Just a thought for you.
Old Feb 13, 2005 | 05:13 PM
AeroPA's Avatar
AeroPA
Buy whatever stereo you want to use. The factory units are so-so, but there are so many aftermarket units out there that are much better. Buy an installation kit, with the wiring adapters, and you're all set. They have great instructions, and you don't have to butcher the factory wiring harness to use them.
Just plug the adapter into the stock wiring harness, and wire your stereo to the adapter.
LOL, great minds think alike, nighthawk.
Old Feb 14, 2005 | 10:59 AM
CharlestonSC's Avatar
CharlestonSC
Smile
Go aftermarket. The factory units typically aren't as high a quality and unless you're going for a restored-to-original quality, most of the time you'll get better sound from putting an aftermarket in there. Crutchfield is GREAT! They don't always have the best prices, but the customer service is top notch. Also, they supply everything you need to get it done, including diagrams and an 800 number to call for help. I've used them for 12 years, and wouldn't go anywhere else for service.
Old Feb 14, 2005 | 11:46 AM
Aerocook's Avatar
Aerocook
I thought about doing an audio upgrade on my 92 XLT but I keep wondering about the rear audio controls. Will they work with an aftermarket stereo?
Old Feb 14, 2005 | 11:56 AM
CharlestonSC
It's my understanding that you can get adapters to make them work, but you have to buy certain head units to accept the controls. If the rear controls are that important, then a factory replacement is probably your best bet. You can call crutchfield, and they should have somebody there that can answer your question better than I could.
Old Feb 15, 2005 | 04:40 PM
bobcf's Avatar
bobcf
www.installdr.com
Old Jun 24, 2005 | 06:03 AM
clarknuss's Avatar
clarknuss
Hi, just read your reply and I want to add this. I installed a Sony indash CD/radio into my sons 93 Aerostar XLT. I bought the harness and the installation was easy. Here is the problem, as long as the fader is ALL THE WAY either to the front or rear the sound is clean. When the fader is adjusted for a balanced sound there is a lot of static coming from the front AND the rear. I thought it was impedance mismatch and had my son purchase all new speakers but to no avail. Has anyone else had this problem? Is this enigma connected to the rear speaker control and or headphone jacks and controls?
Old Jun 24, 2005 | 06:35 AM
IB Tim's Avatar
IB Tim
Welcome clarknuss....to FTE
Old Jun 24, 2005 | 12:16 PM
93nighthawk
Welcome!
Did the the original stereo work fine?
If it did, I would say the issue is with your head unit, not the speakers or wires between the head and speakers. Sony quality has been going down hill for years.
The only other problem I see is that maybe you hooked up wires in the wrong place.
Old Jun 25, 2005 | 04:52 AM
clarknuss's Avatar
clarknuss
when I purchased the radio I also purchased the two wire harnesses made by Metro. And I double checked the wiring to the speakers using a AAA battery. I read other comments on this forum that suggest I should just run my own wires to the speakers because the original ford wiring is a nightmare. I was hoping to find someone who experienced static when they changed to a different head unit and how they defeated it.
Old Jun 25, 2005 | 05:16 AM
clarknuss's Avatar
clarknuss
Thanks Tim, it is my pleasure to be here.
Old Jun 25, 2005 | 09:55 AM
B-Aerostar's Avatar
B-Aerostar
The Aerostar radio speaker harness don't use the same position as other Fords. If you check the wiring diagram it shows rear controls and station tuning in same of the regular speaker wire position
Old Jun 28, 2005 | 06:49 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
NO. On our '91 ext., Circuit City had to rewire all the speakers directly to the head unit (Sony 5700 I think). However, BestBuy said it probably wouldnt be necessary.
And be prepared to pay for their "Free" Installation. Their "Free" Installation cost us about $115-$120 On top of the $185 for the head unit!
