Front driveshaft U-joint's
Old Feb 13, 2005 | 01:31 PM
supercab4x4dually's Avatar
supercab4x4dually
Question Front driveshaft U-joint's
I was working on a buddy's truck,and one of the thing's to be fixed was some new u-joint's in the front shaft.When I went to pull it out of the truck I noticed that the cardnel joint was at the front end and the single u-joint was at the transfer case.Ive done several u-joint's,and front end work on theis ol Ford's,and I HAVE NEVER seen the cardnel joint at the front end.Shouldn't the cardnel joint(double U-joint)be at the transfer case,and the other end of the shaft having a single u-joint be at the front end???
Old Feb 13, 2005 | 05:16 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I have always seen them with the double Cardan joint at the transfer case end too...
Old Feb 13, 2005 | 05:43 PM
supercab4x4dually
I think the T-case was swaped,and the replacment T-case had the other yoke on it,and the driveshaft was turned around so the u-joint's would match the yoke's.Weird.
Last edited by supercab4x4dually; Feb 13, 2005 at 05:44 PM. Reason: missed a letter
Old Feb 14, 2005 | 04:06 PM
buzzbait65's Avatar
buzzbait65
How did it bolt to the front yoke, i believe you need a c/v yoke with a c/v, or does this truck have flanges on the t-case and axle
Old Feb 14, 2005 | 06:51 PM
supercab4x4dually
Instead of the u-bolt's that would hold the cap's in place their is bolt's going threw the yoke on the front end.And instead of bolt's going threw the yoke on the T-case their is u-bolt's holding the single u-joint to it.weird eah?
