Sponsored by: Auxito
98 rough idle
Old Feb 13, 2005 | 11:08 AM
bhaven's Avatar
bhaven
98 rough idle
I have a 98 F-150 4.6 with a bad idle and gets worse when put in gear but truck runs great other than that HELP
New plugs new wires same problem no check engine light. ford dealer said with out check engine light it could cost a lot of $ to find. if you give it a little gas it evens out any help
Old Feb 13, 2005 | 11:33 AM
fordman311's Avatar
fordman311
If it is just rough idle, and hittin the gas helps, it probably the IAC (Idle Air control) sensor. Just finnished writing in another thread about this. Use the forum search tool and look up "IAC" and you'll find all the info you need. When you go to replace it/clean it out cheack my gallery for help, I got some pics of it there. Dont pay anyone else to do it, its real simple and saves the $$. Takes about 15minutes to replace and a couple of bolts. Ususally about $50+ bucks for a new IAC.
Old Feb 14, 2005 | 01:38 PM
BillyBob69's Avatar
BillyBob69
What fordman said. The IAC is located at the top back of the intake manifold. Just remove the plastic intake cover, then unplug the harness from the IAC and then remove the two bolts. It pops right off. Best to replace, (Approx $70), but sometimes cleaning helps.
Old Feb 14, 2005 | 06:16 PM
xallxforxchristx's Avatar
xallxforxchristx
Would the rough idle be a constant problem? My truck's about to turn over 100,000 and I've felt it once or twice in the past month, but once I restarted it, it stopped. What would I look for to tell whether it needs to be cleaned/replaced?
Old Feb 14, 2005 | 06:34 PM
fordman311's Avatar
fordman311
The idle is usually its roughest when the engine is colder. The cold seems to aggrivate the problem. If you find youself having to apply a little of the gas pedal to keep it from stalling out, the IAC is probably the problem. I think when i really felt the bad idle and had to apply gas when it got into mid-low 30's (F) here. But a lot of stuff would affect the temperature at which you would really feel it, such as how dirty it is. Just take the IAC off and check to see how dirty it is. I've made a gallery just for IAC help, because so many people want to know the specifics to fixing IAC problem. Racerguy is going to put a link for the gallery under one of the main threads, but you can still view it now.
Old Mar 4, 2005 | 08:02 PM
xallxforxchristx
Hey Guys, I went to check out my IAC tonight to see if it was clogged or not, but ran into a slight problem. It seems as the IAC is located in a very inconvienient spot...ie. behind the throttle body, next to the fire-wall and under the cowling. Am I looking at the right thing? It looks exactly like what was in your gallery...a shiney tube about an inch or inch and a half long held on by 2 bolts. If I'm looking at the right thing, is there an easier way to get back to it? The engine I have is the 5.4 L V8 in a 98 truck. Thanks for the input.
Old Mar 4, 2005 | 09:28 PM
RoyalFord's Avatar
RoyalFord
I have another post with this same problem... http://www.fordtrucks.com/forums/sho...d.php?t=351325
I found a vacuum leak on the hose that comes from the PCV Valve and connects to the back of the intake. I have heard it is pretty common.
Old Mar 9, 2005 | 08:44 AM
bhaven's Avatar
bhaven
98 rough idle found problem
98 F150 4.6 4X4 truck runs good except rough idle, got check enigne light and took it to the ford dealer, low compression right head they are going to remove head and take it to the machine shop i am at there mercy here hope this is all,the said around $1500 if this is all thats bad
wjjarvis84
Oct 4, 2012 11:01 AM
Mikec35
Aug 16, 2007 05:29 AM
jwford
1997 - 2003 F150
Nov 2, 2005 02:01 PM
nrvelasquez
Mar 28, 2004 12:52 PM
RADVRA
1997 - 2003 F150
Aug 14, 2003 11:16 AM
