own a 03 f150 o/r 4x4, just recently when I start off from a stop and turn I feel a knock or a thump in the steering wheel, this also ocurrs when I am just about to come to a stop with my foot on the brake. I had a tire rotation and alignment the other day they said there was a little play in the L.R ball joint not to bad right but some thing to keep an eye on. This truck has never seen o/r use and is babied all the time .
Any thougths on this would be helpful it is going to Dealer Mon. but you know how dealers sometimes are
Thanks In Advance
Mark
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
