Aerostar Ford Aerostar
Highway Speed Shakes Continue
Old Feb 13, 2005 | 09:05 AM
napaneeont's Avatar
napaneeont
Question Highway Speed Shakes Continue
1993 Aerostar AWD - 4.0L w/OD
229,000+ km
Had van into garage ... changed coil pack, wires and plugs, fuel filter
Driveshaft dropped to check u-joint ... no problem
All new* tires [*under 1 year old]
Problem continues when accelerating up to 80km[5omph] ... van begins to sputter/shake 'violently' ... let off gas pedal ... smooth ... apply gas ... shake
HELP ... I'm beginning to loose my mind with this problem ... any ideas??
ALL input and suggestions most welcome ... Hope somebody can help!
Cheers
Old Feb 13, 2005 | 10:56 AM
copper_90680's Avatar
copper_90680
There was a recall on the Transfer Case a long time ago. Was that done on your van? Also check all engine and tranny mounts. Sounds like you have a resonance problem somewhere.
By the way, do you have an aluminum rear drive shaft? If not, the recall was not done correctly. Another thing, grab the rear driveshaft at the T/C end and check for looseness. May be the bearing on the rear output shaft is worn. Unlikely, but with 229,000km, you might be there.
Old Feb 13, 2005 | 11:29 AM
93nighthawk's Avatar
93nighthawk
Are you getting a CEL, have you pulled codes? Were there codes to tell the shop to replace your coil pack(These usually don't go out unless overheated)? When was the last time you cleaned the intake? The 4.0L is notorious for gumming up and causing accellerating/idling issues. If you search for de-carboning you will get posts on how to do it, very easy.
Old Feb 16, 2005 | 03:37 AM
xlt4wd90's Avatar
xlt4wd90
If you're checking for engine problems, you might try replacing the throttle position sensor. It's only about $30, but they've been known to go out wuite often. And they can cause the problems you mentioned.
good luck
tiopet
19
May 12, 2014 06:29 PM
wasatchtruck
1997 - 2003 F150
Oct 26, 2013 06:12 PM
cabby02nyy
20
Nov 11, 2012 09:00 AM
cfp12
Aerostar
Dec 6, 2000 10:17 AM
