Sponsored by: Auxito
check engine light
Old Feb 12, 2005 | 08:24 AM
r0bin02002's Avatar
r0bin02002
Question check engine light
my check engine light flashes every time i reach the speed of 55 or faster, whats the cause of this? my truck is a 1988 f150 xlt lariat 4x4 v8 fuel injected
Old Feb 12, 2005 | 08:33 AM
tex94F250's Avatar
tex94F250
Have you pulled codes? Try fordfuelinjection.com to learn how. Post the codes and someone will translate them.
Old Feb 12, 2005 | 08:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
r0bin02002...interesting screen name...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
...MOVED...
Old Feb 12, 2005 | 06:51 PM
code_red's Avatar
code_red
Wink
My check engine light flashed on and off right after the crankshaft position sensor went out. It did it also when my alternator went out. I have a 97 with a 4.6. Not sure if this will help you out, but it could .Gather your codes and go from there.
