Good morning y-all. I am trying to find the answer to a looming question. I have an 87 F150 2wd and am lifting it 4" most of the kits are for a 4wd. My question is, will the axle brakets for a 4wd fit the 2wd models. Or are they desinged differently.
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
They are designed differently. Check the forum for suspension/lift kits and our sponsors for a kit. It would also be worthwhile to add a levelling kit. I'm presuming you are looking for suspension travel and clearance.
