1978 - 1996 Big Bronco
VIN decoding help
Old Feb 11, 2005 | 10:47 PM
cougar_1987's Avatar
cougar_1987
VIN decoding help
I have looked at this site and found other sites that were mentioned to decode VIN numbers but they haven't worked for me yet. So I thought I'd ask here....Anyways, I am looking at a 1986 or so Ford Bronco and I got to what as close to a VIN number that I could read. It is 1FMDU5Y80FA737280 I'm not sure if the "F" is a L or 1. I know that the 10th character is for the year anyway but I need help with the axle, trans, engine identification. That is what I could make out of the VIN number. If anyone can help me at decoding this I would really appreciate it. Thank you.
Old Feb 11, 2005 | 11:10 PM
rick90yj's Avatar
rick90yj
www.carfax.com will tell you what you need. I ran what you have and it says it's not a valid VIN. Keep trying to read it.
Old Feb 12, 2005 | 07:08 AM
tex94F250's Avatar
tex94F250
If "Y" is your 8th character you have a 4.9 Inline 6 cylinder engine. The VIN in your post is a little off. The 300 (4.9l) I6 is the only 6 cylinder option I know of. There should be a data sticker on the door jamb to indicate your transmission and axle. If you will get these codes and post them, someone will give you the answer.
Old Feb 12, 2005 | 09:08 PM
Tim Halliday's Avatar
Tim Halliday
Here is Ford's VIN decoder:
https://www.fleet.ford.com/maintenan...ls/default.asp
Here is what I tried to gues that your VIN might be. Not sure about the 8 or the 73728, but th rest of the numbers work.
1FMDU15Y8FLA73728
1FM - Ford Multipurpose Vehicle
D – Brake system - Hydraulic / GVWR -5001 - 6000 lbs.
U15 – Bronco 4X4 XL or better
Y – 4.9L I6
8 – Check digit
F – Model Year – 1985
L – Wayne, Michigan Truck Plant
A73728 – Sequence Number
To get the axle and transmission information, you need to see the sticker inside the driver's door.
