351C help
Old Feb 11, 2005 | 03:45 PM
bshackelford711's Avatar
bshackelford711
Exclamation 351C help
Does anybody no all the specs for a 1972 351C with a 4 speed trans. This is in a 1968 Ford F-100 that i got last night. We think that the motor and trans came out of a 1972 Mach 1 Mustang. How can i found out what this came out of.
Old Feb 11, 2005 | 11:05 PM
mcapri1984's Avatar
mcapri1984
Is it a two or a four barrel?
Old Feb 12, 2005 | 02:20 AM
whd507's Avatar
whd507
if the aluminum tag is still bolted to the coil bracket, it will tell you. if not, you know its 1970-74 if its really a Cleavland engine.
Old Feb 12, 2005 | 06:55 PM
4Cammer72's Avatar
4Cammer72
two or four barrel only lets you know if you have the quench heads or not. they are the good ones but you could get a two barrel in a mach 1 as well.
Old Feb 17, 2005 | 02:29 PM
blatherskite's Avatar
blatherskite
Not all 4V heads are 'quench' head either.........
Old Feb 23, 2005 | 03:42 PM
bshackelford711
it is a 4 barrel carb. it is no tag on the motor any where that i can find.
Old Feb 24, 2005 | 11:55 AM
whd507's Avatar
whd507
cast iron intake or aluminum?
get parts numbers off the intake and heads, that will help
