Overheating
Old Feb 11, 2005 | 10:55 AM
thewatt's Avatar
thewatt
Question Overheating
I have a 1986 ford f-350. when i am pulling under a load the temp guage starts to move up. At idle it can run all day and not even move. i put an auxilary fan on which seemed to help but it worries me that it might overheat one day. i have a new fan clutch, thermostat and radiator. Any ideas of what i could check? help
Old Feb 11, 2005 | 02:50 PM
travisd's Avatar
travisd
On my chevy suburban, (don't hate me for the bowtie), all of the increase in temp that I noticed on my gauge was caused by the heatup of the tranny fluid. After installing a separate tranny cooler, I've noticed the same kind of loads show no effect at all on the temp gauge.
Old Feb 11, 2005 | 03:29 PM
thewatt's Avatar
thewatt
When i first bought the truck the tranny cooler that was on it was to small. i found that out the hard way when my tranny burned up and i had to get a rebuilt. there was a bigger tranny cooler installed at the time of the rebuild. that was an expensive discovery. i was thinking maybe the exhaust pipe was to small or maybe it has something to do with the banks turbo. the exhaust temp guage rises pretty quickly when under a load and i will max it out at 1150 when going up a steep grade pulling about 8000 lbs. thanks for the reply.
Old Feb 11, 2005 | 07:26 PM
RedHorseUp's Avatar
RedHorseUp
my 84 250 did that when the timing was off a tad. don't remember
if it was retarded or advanced, but gettin it timed right stopped the
overheating.
Old Feb 11, 2005 | 08:07 PM
ford390gashog's Avatar
ford390gashog
the rad could be clogged did you flush the system
Old Feb 12, 2005 | 06:53 AM
Holmesuser01's Avatar
Holmesuser01
Red face Similar issues with a 150
My 1983 150 w/ 351W does the same thing. New radiator, water pump, t'stat (195) and hoses. I am stumped. The temp goes up to 215 degrees on the interstate. I used a REAL temp gauge to check this out. Other than this, the truck runs perfectly.
My truck has a factory secondary fluid cooler installed in front of the a/c condenser.
BTW: the A/C condenser is not bug incrusted, and has good air flow-thru. The fan clutch is OK, too.
Strange.
