Fuel issue and question
Old Feb 11, 2005 | 09:22 AM
blu's Avatar
blu
Filled the tanks this morning. It was probably 25 degrees out truck started right up. Let it warm up for 5 minutes while I removed the snow plow drove 10 miles to get diesel.
After fueling start the truck seems like its missing on a couple of cylinders -- sit at the pump for a few minutes till it smooths out. Drive 30 miles after that at 2400 rpms SURGED a few times after pulling away from pump but did not cut out. Drained some water from the fuel filter/water seperator when I got to work. Any ideas on what to check first? I have to tow a trailer 300+ miles on Monday thinking of renting a truck so I'm not left hanging on the highway somewhere. The truck started flawlessly till I re-fueled. I'm guessing I have water in the tanks,air in the system,return line issues or all of the above.
Draining water from the filter? While truck is running do you open bottom drain till fuel comes out?
Thanks,
Anyone have any suggestions.
Old Feb 11, 2005 | 10:14 AM
cemenacho's Avatar
cemenacho
are you still using that God-awful water separator on the firewall? or so you have a different setup? that would be my first question (and mod)
Old Feb 11, 2005 | 11:38 AM
toyrobotus's Avatar
toyrobotus
Year and and engine?
Old Feb 11, 2005 | 01:46 PM
blu's Avatar
blu
The year is 1989 IDI 7.3L diesel. Filter is not on the firewall.
Old Feb 11, 2005 | 02:57 PM
cemenacho's Avatar
cemenacho
1)change the fuel filter.
2)get some stanadyne (blue label or winter formula green label) additive
3) start going to a different place for fuel
Old Feb 11, 2005 | 03:17 PM
csramsey640's Avatar
csramsey640
1. correct
2. correct, if you cant get stanadyne, get a very good brand product for water/anti-gelling
3. correct
tseidel
6.7L Power Stroke Diesel
74
May 23, 2021 01:29 AM
Jayybird
Oct 5, 2010 01:12 PM
dknouse
19
Sep 16, 2010 04:35 PM
wizard
Nov 16, 2008 03:52 PM
mckejoha
Sep 25, 2007 12:28 PM
