9.5 Rearend
Old Feb 10, 2005 | 08:22 PM
Col Flashman's Avatar
Col Flashman
Question 9.5 Rearend
FTE'rs
It has been suggested because of the 400 FPT my 300 I-6 puts out that I should start looking for a Complete Ford 9.5 rearend, it was also stated that these would be hard to find.
Anybody have any ideas about locating one?
Thank'ee
Colonel Flashman
Red '58 Mercury M-100 Truck
Blue '58 Mercury M-100 Panel Truck
Old Feb 10, 2005 | 08:25 PM
mustange70's Avatar
mustange70
The good ol' Ford 9" will take that with no questions asked.
That be a well built 300 to put that kinda of power out
Old Feb 10, 2005 | 09:01 PM
Col Flashman
M.70
Thank'ee for your reply.
The "Olde Girls" engine also produces 300HP w/ a 10:1 CR & she's now about 308 or 312 C.I.'s
How does this combination sound then, Equaloc & 3.25 gears w/ an HD Yoke.
Thank'ee
Colonel Flashman
Old Feb 10, 2005 | 11:22 PM
mustange70's Avatar
mustange70
Sounds good, but you don't really need a heavier yoke, a 1330 will get the job done fine, in my flareside (9" rear, 3.25's and posi, only has the 28spline axles though, but it had the gears I needed) i'm pushing 350hp and near 450lb of tq in a built windsor, i drive er' hard and other than the nasty wheel hop (i have tractions bars to install for that little problem) i haven't had a problem with it and i shouldn't either, i also have the parts to convert it to rear disc brakes which will get done this summer.
Old Feb 10, 2005 | 11:37 PM
Col Flashman
M.70
I'm not all that up on what we are discussing here, what is a 1330 Yoke?
Thank'ee
Flashy
P.S.
Know any good sources for body parts, badges & side flashes for my rigs?
Old Feb 10, 2005 | 11:47 PM
mustange70's Avatar
mustange70
A 1330 is the size of your u-joint, most half tons (like 2wds) will use a 1310, which is weaker, but works fine in most stock and semi moded applications (you would be able to use one without problems i would think), a 1330 u-joint was used in heavier 1/2 tons (like a 4wd for ex) and 3/4-1 tons, then there are 1350, 1410's, etc, the higher the number the stronger the u-joint. If i were you, when you swap in the new rear i would get a shop to cut the old yoke and weld a new 1330 joint back on, then ask them if your yoke that you have (or will have anyway) is a 1330 or a 1310, then if its a 1310 they should be able to get you a 1330 are tell what-where to get one from.
A good place to get parts from for your mercs (your lucky the just put a bunch of new laws and you can't import merc trucks anymore without going through a lot of work) would be lmctrucks.com. (free cataloug too)
Old Feb 11, 2005 | 12:50 AM
Col Flashman
Unhappy
M.70
Thank'ee for the Intele.
I've the latest LMC Cat. & I do not recall Merc. badges & such.
That's not good to see this about that new law.
I've a '58 M-100 Panel Truck that I need to retrieve from Elma, Manitoba.
What kind of Red Tape & Hoops am I going to have to jump through?
Cheers
Flashy
Old Feb 11, 2005 | 12:48 PM
mustange70's Avatar
mustange70
well if you have already bought the truck i would start getting ahold of some brokerage's on the border crossing that the truck would be brought through, they will know what to do, but offhand i couldn't really tell what you will have to do, it has that mercury didn't make trucks in the states and such, i know that there are other types of vehicles that have this problem as well, its doable by all means, just a pain in the but.
Old Feb 11, 2005 | 12:55 PM
Col Flashman
Talking
I've been attempting to Make room for her here for about 9 months now & not being very successfull @ it.
What would these brokerages be Listed As or Under?
That's funny, because that's exactly how Uncle purchased the M-100 from a So. Cal. Dealership.
He'd seen a truck load of them that Father was delvering down to Mexico & went to the Local Ford/Merc. Dealership & stated that he wished to own one.
He had it w/ in the week.
Flashy
Old Feb 11, 2005 | 01:08 PM
mustange70's Avatar
mustange70
They would be under brokerages in the yellow pages (not the type that arre in the stock market), but usually you can call the custom's building at the border crossing and they should be able to refer you to a broker.
mrcman58
1961 - 1963 F100 Unibody
Nov 20, 2015 06:04 PM
Flashman
Sep 28, 2013 06:11 AM
Col Flashman
Sep 15, 2013 11:59 PM
Flashman
Oct 6, 2010 09:04 PM
Col Flashman
Mar 14, 2006 07:50 PM
