77 250 dash cluster
Old Feb 10, 2005 | 07:34 PM
RDON's Avatar
RDON
77 250 dash cluster
Is it a big problem removeing the Dash cluster. I don't need to fulley remove it as long as I can lay it back to clean the circuit board
Does the heater ***** just pull of. I don't have air so it looks easy.I cant get the dimer light to work all the time. So I though if I could just lay it back to clean the board it might fix that problem. Sure could use some help on this one.
THANKS Don
Old Feb 11, 2005 | 04:48 AM
f250rangerexplorer's Avatar
f250rangerexplorer
yeah theres like five screws and remove the ***** and it should come right off.
Old Feb 13, 2005 | 10:24 AM
RDON's Avatar
RDON
Thumbs up
Youwere right,It was a pice of cake takeing the I P off.The hardest part of the whole thing was the wiper *** I couldn't get it to releace broke the clip.So when I put it back I put a small amout of Lock tight that way I can still remove it. I had to glue some of the lights in becuase the back is crumbling big time,But if will work till I can find another.All the lights are working and bright.
Thanks for the help Don
