dana 60 ball joints
Old Feb 10, 2005 | 05:21 PM
threefords's Avatar
threefords
dana 60 ball joints
how hard is it to change ball joints on a d60 front end? do I need a hub puller? the truck is only 4 years old.
Old Feb 10, 2005 | 06:41 PM
SoCalDesertRider's Avatar
SoCalDesertRider
No hub puller needed for front axle. You need the 4wd hub socket though. It would be helpful to have snap ring pliers, ice pick or small screwdriver (for the hub retaining ring), and 2 pickle forks, small one for the tie rod end (don't unscrew the end from the tie rod, unless you want to re-set the toe) and big one for the ball joints. Take the knuckles to a local shop with a press and have the old joints pressed out and the new ones pressed in.
