Sponsored by: Innova
Quick Question...
Old Feb 10, 2005 | 04:12 PM
Roushians's Avatar
Roushians
Quick Question...
Hi,
BestBuy here in Canada has JBL 10" subs for $80US ($100CAD) until stores close tonight. I think I should buy 2. Now they are 250W RMS @ 4ohm. Do I acquire a mono amp that's rated for 500W RMS @ 4ohm to run 2 of these subs??
Or do I acquire a 250W RMS @ 4ohm to run both?
I've been struggling with this problem. Thank you dearly if you can help me before Best Buy closes tonight.
Old Feb 10, 2005 | 04:27 PM
fsujoe1's Avatar
fsujoe1
It depends on how you want to wire them up. If you wire them in parallel the amp will see a 2 ohm load but each speaker can still dissipate the 250 W.
You could use a 2 channel amp that puts out 250 W x 2 @ 4 ohms, but you don't really need 2 channels for bass.
So your best bet is a mono amp that puts out 500 Watts RMS @ 2 ohm and wire them in parallel.
Old Feb 10, 2005 | 04:46 PM
JERRY'S PSD's Avatar
JERRY'S PSD
most 2 channel amps will not run a 2 ohm mono load, just want to make sure the amp is will run a 2 ohm mono load.. overwise you could burn up the amp..
