81 300
Old Feb 7, 2002 | 10:34 PM
brknfrd's Avatar
brknfrd
I'm hoping someone might be able to help me with this, I've got a 300 that doesn't like to idle, I believe I have plugged all the vacuum leaks but the one thing that really confounds me is that it idles terrible but when I pull the #6 plug wire, it smoothes out and the idle increases. I've checked the timing and firing order repeatedly to no luck, I will add that I have only had this truck a short time and may be putting together someone else's puzzle, does anyone know what I may be missing?
Also, does the vacuum advance use ported or manifold vacuum?
thanks
df
Old Feb 10, 2002 | 06:01 PM
lastchance's Avatar
lastchance
81 300
Well, one thing I can help you with is the vacuum advance. It should go to ported vacuum. As far as the miss and the mystery of pulling the number 6 plug wire I think I would do a compression check. sounds like maybe you have a burnt valve or a blown head gasket, but a comptression test should show something up. By the way, Welcome to FTE!
Old Feb 10, 2002 | 10:23 PM
brknfrd's Avatar
brknfrd
thanks for the reply, I figured the dist. used ported vac. but didn't want to assume. I did a compression check the other day and it didn't turn anything up, I think the carb is shot, that would explain the awful idle but, the #6 wire's got me.. Is it possible that I have a newer dist. with an older motor? or a combination thereof (I know, long shot but I'm up for anything....) thanks again,
df
Old Feb 10, 2002 | 11:57 PM
rocky's Avatar
rocky
Sounds like a problem I had last week, maybe it will help. Had a lousy idle, got better when I touched the plug wire. Turned out the spark-plug wire and cap was bad, and spark from one cylinder was arcing to the radiator hose-clamp. Drove me nuts until I looked at it in the dark, then the problem was revealed.
Old Mar 7, 2002 | 11:52 PM
andy_s's Avatar
andy_s
did you check to see if your plugs were fouled or your wires were bad.
Old Mar 8, 2002 | 03:49 PM
BRUTUS250's Avatar
BRUTUS250
Creedog
Sep 21, 2020 09:56 PM
cooktimj
Oct 7, 2013 07:12 AM
HEpTJJ
Sep 11, 2013 10:58 PM
bigric
1978 - 1996 Big Bronco
Jul 7, 2003 11:53 AM
gadams
Aug 22, 2002 09:25 PM
