Dealership diagnostics
Hey, everybody. I was thinking about taking my truck to a local dealer and having them hook my truck up. I'm not getting a check engine light or anything and it is starting fine and all. I'm just sick of the hesitation and stuttering during acceleration. My question is, being no CEL, will they be able to tell me anything about the way my truck is running that I don't already know. I'm taking it in to have the front end componets checked out anyway. Is it worth the $70 or am I just ****in' into the wind?
Rich
2000 Rcab 4.2 5sp 2WD
106,000+ miles and counting
Rich
If it will help your piece of mind,it'll be worth it,but don't expect much. Unless you have an unusually stellar service department, they will probably just say there's no problem, and then recommend a tune up at shop rates (read: expensive) to solve your problem.If you are capable of doing a tune up yourself, I would do it.
travlnman, I use the Motorcraft/.054". I've already been through the Bosch fiasco. I tried them once for about a month and changed them back out after stumbling across a thread on here. It actually ran worse than it does now.
BOF, I cleaned the throttlebody about 8-9 months ago. At the same time I changed the plugs, wires, fuel filter, cleaned the K&N filter and reoiled. I let the filter sit after re-oiling for about a week while running a paper filter. Re-installed the K&N and waited another week and cleaned the MAF. I completely disassembled the the MAF from the air cleaner housing and soaked the sensor wires in CRC electronics cleaner for a few minutes. I then sprayed the wires again, let it dry and re-installed. It really didn't run any better then than it does now.
Maybe the father-in-law was correct. Maybe I'm expecting too much from a truck with 106,000 miles on it. Probably 70-80% of those miles have been at 75-80MPH. Maybe I've just worn it out. It doesn't burn any oil that I've seen and might use a half quart in 5000 miles, if I go that long. It just bothers me because the truck still cleans up real well, it just doesn't run as well as it used to....that being the most important part.
Do you burn oil, knock, have water in the oil? If not, it's probably not worn out. I have 155,000 + on my 2002, and it runs fine to me. I don't burn any oil between changes, and it still pulls strong when youget on it. Probably 80% of my miles are on the interstate at 75-80 mph. I just replaced my front rotors on Saturday, and was able to put the factory pads back in(mainly because the store gave me the wrong new pads). I put every mile on it myself, so I have the luxury of knowing exactly how it was treated. Today's vehicles are a little more durable than say, 20 yrs ago. Along with modern oils that protect light years better than the old dino juice, you can get a lot more life out a vehicle than our parents could. Anywhere from 200-300k is not unusual these days. We'll figure it out, just need a little more time to think, but someone has the answer.
