Limited slip
Old Feb 10, 2005 | 07:14 AM
SBV45's Avatar
SBV45
t_j82, let us know what he says.
Old Feb 10, 2005 | 08:31 AM
pdbd's Avatar
pdbd
Originally Posted by t_j82
Yesterday I went to leave my driveway and the right rear wheel ended up on a patch of ice, I put it in drive and gassed it and went no where. I goosed it again and still no movement. I pointed my mirror down at the left tire and wrapped it up to about 17k and it never moved and neither did the truck. So I had to go into 4wd because ONE tire was on ice. Didn't know I bought a one legger. Window sticker shows L/S installed.
Called the dealer and spoke with the svc writer and was told to bring it in. Got it back today, was told everything works fine. I was handed a sheet from ford that said to lightly apply the parking brake while accelerating to make the L/S work... WHAT?! So does this mean that I have to drive with my brakes on while in slippery conditions for the L/S to work?
This is the first I have ever heard of this.... Anyone have words of wisdom, or at least logic?
This techneque is used when you do not have LS or posi. It causes the other wheel to bite. Take it to another dealer. I don't like mine either I call it the limited slipsalot.
Old Feb 10, 2005 | 09:36 AM
utahtom's Avatar
utahtom
I have been carrying 400lbs of sand in my truck since December so I think the weight thing is moot.
Ditto, I always keep 300 lbs of sand bags plus misc materials, ski's and barley pop-
Old Feb 10, 2005 | 10:42 AM
RockinB's Avatar
RockinB
Had a 2000 F250SC SB 7.3 6 speed never noticed any help from LS.This truck slipped on wet grass. Lost that one to a flood and now have 2005 F250SC SB 6.0 6 speed and the LS works most of the time. I agree they need to go back to the drawing or not charge for this option.
Old Feb 10, 2005 | 11:03 AM
PSD6litre40's Avatar
PSD6litre40
PSD60LFX4 had a discussion about this not long ago. I believe that Detroit Locker has a diff coming out soon that will be LS and you can manually engage it to full lock by the push of a button. My truck has LS too fuctions the same way. ****es me off when I try to do a burnout and it only spins one wheel 80% of the time.......
Old Feb 10, 2005 | 11:08 AM
ZBeeble's Avatar
ZBeeble
As I understand the recomendation (and the description on howstuffworks), it would seem that this type of limited slip requires a little traction to make it work. Howstuffworks calls this type of differential a 'TorSen' ... and it seems reasonable that a small amount of friction is require to make it engage.
The description says that the operation is to apply some multiple of torque (say 5 times, for argument) to the non-spinning wheel. However, if the spinning wheel has 0 torque, 5 x 0 is 0. Applying the brake increases the torque applied and thus the other wheel moves.
Don't mistake this for a regular open differential where the parking brake is also of limited aid. In that case, if your brakes are properly adjusted, nothing happens. An open differential applies the same torque to each wheel --- so when you apply the break, the same torque is being absorbed from both wheels and the result is that you don't move.
Old Feb 10, 2005 | 11:37 AM
AGE mechanic's Avatar
AGE mechanic
HERE IS THE ANSWER............
Dont ask me why, but, according to Ford tech, you must apply light pressure to the brake peddle or set E-brake on lightly. It works, try it. Miss those Detroit Lockers?
Old Feb 10, 2005 | 11:42 AM
labenske's Avatar
labenske
I know that everytime I've powerbraked my truck, I've layed down dual rubber. Usually if I just stomp it, I can feel one wheel just barely wanting to slip.
So I would agree, brakes do help the rear out somewhat.
P.S.
Why do some people hate to put their trucks in 4X4?
Old Feb 10, 2005 | 12:10 PM
LOOnatic's Avatar
LOOnatic
I have a non-LS or "open" differential.
I understand your above statement but do you know what my inner rear wheel does when i make a U-turn?
I can't figure out if a limited slip or non-slip is better for turning.
Old Feb 10, 2005 | 12:20 PM
t_j82's Avatar
t_j82
Originally Posted by labenske
P.S.
Don't hate it, just expect what I paid for to work. I use 4wd all the time up here just not on otherwise dry pavement.
Old Feb 10, 2005 | 12:26 PM
ZBeeble's Avatar
ZBeeble
Well... when turning an LS differential shouldn't kick in. It's a bit of a balancing act, but as I understand, it's calibrated to accept upto a certain ratio of difference ... say 5:1 or somesuch.
So when you turn a corner, your inside wheel is (say) turning once for every 3 times the outside wheel turns (these trucks don't turn too sharply) so the whole mechanism isn't kicking in (much).
Old Feb 10, 2005 | 02:52 PM
Springer's Avatar
Springer
ZBeeble,
The description of the Torsen is accurate but I don't think Ford is using a TorSen differential. In the world of L/S differentials TorSen is relatively new. Ford is using a standard clutch pack design. That's why the dealer can offer to "tighten it up some." I'd be thrilled if they started installing TorSen or Eaton differentials.
BTW, the torque spec for my hotrods 12 bolt posi is 100 lb-ft to overcome the clutch pack manually.
Old Feb 10, 2005 | 03:11 PM
  #28
Tekrep's Avatar
Tekrep
After carefully inspecting the two 15 foot black stripes that used to be BFG tread… my L/S kicks in immediately- no brakes, just a slight roll and then the SCMT tune makes short work of my tread. The marks start at the same place- at least as far as I can tell. I did, however, gets stuck in a very precarious driveway last year, in 4 high, and 4 low. Was trying to pull a Subaru out. How embarrassing. One rear, and one front tire were slipping. I didn’t think to hold the brakes- must have been the alcohol.
I have seriously considered getting an aftermarket locker. I haven’t done a ton of research yet, but was considering front and rear ARB air lockers. The rock crawlers swear by them, but if my truck goes rock crawling, it won’t be on purpose. I just want to get out of the driveway! I would be interested to hear if anyone has experience with one brand/type or the other. I would like a REAL limited slip/locking diff. They are a bit pricey, though.
Old Feb 10, 2005 | 06:27 PM
  #29
SBV45's Avatar
SBV45
Revving it up will certainly make it slip. Go real slow and it shouldn't slip. If you look at Ford's documentation, they say to go real slow.
"As when you are driving over sand, apply the accelerator slowly and avoid spinning your wheels."
From the Truck and SUV manual
Old Feb 10, 2005 | 06:54 PM
  #30
tpalm5's Avatar
tpalm5
What ford really needs is the option of a locking rear differential... cough nissan titan cough chevy silverado. There are so many situations where an extra wheel of traction could have gotten me farther or out a of somewhere more easily!
