lifting a 79 supercab
Old Feb 9, 2005 | 10:34 AM
jheeter's Avatar
jheeter
I was wondering if anyone knew of a lift kit for a 1979 f-150 4x4 supercab. All the kits I'm finding are for regular cabs w/ front coils. Even the local dealers can't find one.
The truck is sitting stock right now. I am planning on putting on a set of 35's and also trying to improve the ride so I dont want to use a body lift.
Or can someone tell me if there is an easier (cheaper) method of swapping springs or something of that nature.
Old Feb 9, 2005 | 11:03 AM
ivanribic's Avatar
ivanribic
You will want to buy a kit for an F250. Supercab F150's used a heavier frame and leaf springs up front . . . the F250 kit will bolt up perfectly.
You'll definitely want springs up front. Do a search for "shackle flip" or look in my gallery for the shackle flip. This is a good CHEAP alternative for the rear of the vehicle. Depending on the height lift you'll need to look into things like brake lines, shocks, drivelines, steering, etc.
Old Feb 13, 2005 | 02:58 PM
fatdog's Avatar
fatdog
Super cab lift
I lifted my 79 super cab 4x4 using a 79 f250 spring kit from rough country. I only went 2" because I only tow a boat and camper with mine, no real offroading and I'm only running 33" tires. Everything was a direct bolt in.
Swamp
Old Feb 14, 2005 | 09:07 AM
jheeter's Avatar
jheeter
How does the rough country kit ride? Did you notice a difference?
Thanks for the info.
Old Feb 14, 2005 | 11:36 AM
fatdog's Avatar
fatdog
rough country lift
I am extremely happy with the ride. I ended up removing the bottom factory leaf spring in the rear. The reason I did this was that with the lift the truck ended up with a slight rake to it where the front was lower than the rear. I like my truck to sit level. I think this also really helped the ride. It's just firm,but not harsh. It rides as good as the new F150's and even better than my Dad's 2000 light duty F250. The only thing about rough country that I didn't care for was the fact that the shocks have started to rust already. I only have about 800 miles on the truck and it isn't ever driven in snow or salt only the rain. I figure a shock like this should have a better finish that. I will buy them again for the ride, but I will clear coat them befor I put them on.
Swamp
Old Feb 15, 2005 | 06:20 PM
75hiboy's Avatar
75hiboy
you can get a set of f250 springs and blocks for the back
Old Feb 15, 2005 | 07:18 PM
MHull's Avatar
MHull
Not sure if it helps any, but I have a 79 f150 ranger supercab that I just picked up, and the previous owner had 35 12.50s on it, and they worked just fine with the stock suspension. No rubbing or anything. So if your main motivation is to fit 35's, you may not need a lift.
jamestw1977
Feb 24, 2010 09:47 AM
Murph2006
Offroad & 4x4
Nov 11, 2008 10:43 PM
cszeman
Mar 26, 2008 02:46 PM
lud04X
Offroad & 4x4
Apr 24, 2007 12:47 AM
DonnieD
Feb 4, 2000 04:29 AM
