hey guys...
i have a 1996 bronco w/ a 351. currently it has been having a problem starting after sitting for about 20 - 30 mins. if it sits over night, it isnt as hard to start. i just cant figure out what the problem is. i saw a post that said about the icm on the distributor, but i dont have that. i have an msd 6a box and blaster coil now. any help who be greatly appreciated...
check and clean battery posts and wires. if they look coroded replace them. make sure the starter cable is tight to the starter post. what plugs are you using
thanks for the replies guys...
the timing is set at 13 without the spout....i have not checked the battery cables....and im using plain jane autolite plugs...i will try to check the cables soon...thanks again
