Speedometer
Old Feb 8, 2005 | 10:58 PM
Buzzman222's Avatar
Buzzman222
Speedometer
What would cause a speedometer to Flucuate up and down? Clueless. also having strange other electrical problems other electrical equipment isnt working right. Weird.....maybe i should run it over a big curb! .....last time i did that it fixed the pull to the right in my vehicle lol.
Old Feb 9, 2005 | 09:56 AM
jim_2002's Avatar
jim_2002
hi there,I have the same problem on a 96 E-350,the speedometer works great up to 100kph,oe even 110,but over that it spikes up and down,,I am still looking for advise on this myself,I did notice that when I changed the ignition tumblers that it got better,beats me,any help would be most appreciatted..Jim
Old Feb 10, 2005 | 11:08 AM
Franklin2's Avatar
Franklin2
Well I see one of you has a later model, so in that case I would check back at the rearend and see if there is a sensor screwed into it. If there is, take it out and see if there are any metal shavings on it. If you happen to have an older truck with the cable, then I would take the cable loose from the tranny, and then take out the housing that it plugged into and inspect the plastic drive gear.
