'05 Egr
Old Feb 8, 2005 | 10:08 PM
TERSEJR's Avatar
TERSEJR
'05 Egr
I read the past threads on this, but I am alittle confussed still. Is there an EGR plate on an '05 6.0? Can the plug just fall off or does the "plate" have to fall off too? I saw the plates were on again off again for a few years of the 6.0's.
Old Feb 8, 2005 | 10:21 PM
FSeybert's Avatar
FSeybert
2005 Egr
Pull the plug. Check the Tech Folder above if desired, or needed to find the EGR valve. Pull it. It is something that is designed into your trucks engine to meet EPA regulations, but in my mind, does more harm than good. Pull the plug and be done with it. I pulled the one on my 2005 PSD and have not had the CHECK ENGINE light come on. Recirculation of exhaust gasses into the intake is nothing but bad news.
Old Feb 8, 2005 | 10:24 PM
TERSEJR's Avatar
TERSEJR
I can see from the pic's that it will give more boost pressure by not going through the EGR. I just wasn't clear as if the new '05's had the throttle plate or not. Thanks
Old Feb 8, 2005 | 10:29 PM
duMAURIER's Avatar
duMAURIER
From what I understand I would love to pull the plug on the EGR vavle. I don't own a decoder or anything like that. How would my warranty hold up if the truck was taken in with the EGR disconnected? i would hate to foot the bill for engine problems over this!
Old Feb 8, 2005 | 10:31 PM
TERSEJR's Avatar
TERSEJR
Plug it back in before hand.
Old Feb 8, 2005 | 10:51 PM
FSeybert's Avatar
FSeybert
Agreed, plug it back in before taking it in.
Old Feb 9, 2005 | 08:16 AM
hollywood43's Avatar
hollywood43
I have a stupid question -- will the codes clear after it's plugged back in or will they need to be manually cleared? Thanks!
Old Feb 9, 2005 | 09:53 AM
Daryl Hunter's Avatar
Daryl Hunter
Hi hollywood43,
Welcome to the 6.0 forum and to FTE. Please take a moment to check out the Welcome sticky post at the top of the forum page as well as the other stickies there. Lots of links to great threads and other information. The search feature works great too
And for your viewing pleasure, check out the link to the Posting and You public service announcement:
http://www.albinoblacksheep.com/flash/posting.php
The light will go out after several driving cycles - five I think. If not, then it can be cleared by disconnecting the batteries.
Old Feb 9, 2005 | 03:40 PM
fnenninger's Avatar
fnenninger
Were is the tech folder?
Old Feb 9, 2005 | 03:50 PM
14u2nv's Avatar
14u2nv
i pulled mine and eng light came on plugged in my predator and it wouldnt clear the code plugged in the egr and had to use mt snap on scanner to clear the code
Old Feb 9, 2005 | 04:13 PM
hollywood43
OK, thanks for the help. I won't disconnect mine until I have a way of clearing the codes on my own.
Old Feb 9, 2005 | 06:05 PM
fito1411's Avatar
fito1411
i have a 2005 crew cab diesel 4x4 with a 6.0 build date 12/04.I unplugged the egr valve at 20 miles.have 2200 miles on it now.With no issues no lights or anything.
Old Feb 9, 2005 | 06:09 PM
Daryl Hunter
Doh ---> http://www.albinoblacksheep.com/flash/posting.php
The tech folder is one of the stickies at the top of the forum page. It's pretty easy to find. Just look for Read First: ..................Tech Folder..............
Old Feb 9, 2005 | 08:26 PM
TERSEJR's Avatar
TERSEJR
I pulled mine today with no problems or lights. I did notice the improvement in the throttle responce. We will see how the milage goes.
Old Feb 9, 2005 | 08:29 PM
TERSEJR's Avatar
TERSEJR
Oh ya I forgot.... I've got 2270miles when pulled and a full tank of fuel. I'll see if there is any improvement.
