General Automotive Discussion
Stoneage Jeep?
Old Feb 8, 2005 | 04:15 PM
FLgargoyle's Avatar
FLgargoyle
Stoneage Jeep?
A friend of mine just bought a '96 Jeep Cherokee 2wd, and told me it had a straight front axle. I didn't believe him, so I crawled under there and looked- sure enough; straight axle! And people say the Twin I-Beam is crude! How late did Jeep use this set-up? Or are they still using it? I assured my friend that at least it probably won't need much work over the years...
Old Feb 8, 2005 | 05:20 PM
cjben's Avatar
cjben
If I remember correctly all jeep xj's have solid front axle,clear up to 2001 I believe when they replaced it with the IFS liberty
Old Feb 8, 2005 | 05:21 PM
Chris_ce's Avatar
Chris_ce
I think they stopped with the end of the Cherokee's. Unless you are talking 4x4 then I believe the cj7 type still run a straight axle. I am hoping to get a Cherokee or cj sometime soon They are about the only thing small enough to run the trails around here that still has the straight axle.
Old Feb 8, 2005 | 11:42 PM
'961506's Avatar
'961506
jeep xj is the newest wrangler model. And I believe it uses Dana 35's, not very strong, but better than IFS. I would swap a Dana 60 under that. lol
Old Feb 9, 2005 | 01:42 AM
V10man's Avatar
V10man
It was a cost savings idea from Jeep. They could use the same suspension for 4x2 and 4x4.
Old Feb 9, 2005 | 08:01 AM
cjben's Avatar
cjben
not trying to be critical here,but the xj is the midsize cherokee. the tj is the newest short-wheel base wrangler. not sure the letter designation they are giving the new stretched wrangler,the limited
Old Feb 9, 2005 | 09:04 AM
rebocardo's Avatar
rebocardo
FWIW: You may get in the habit of lifting an old Ford by the radius arm, never do it on a Jeep, they bend, I know from experience :-(
Old Feb 9, 2005 | 09:08 PM
'961506's Avatar
'961506
cjben, thank you, it was my mistke. The tj is the new wrangler, thanks for catching thiat
Old Feb 9, 2005 | 09:35 PM
oldhalftons's Avatar
oldhalftons
whats wrong with a strait axle?
