running rough
Old Mar 20, 2002 | 03:53 PM
stevelee's Avatar
stevelee
running rough
my 1986 f-150 seems to run rough when it idles or is in park. seems to
be choking out,missing. i have to give it gas in park or a stop light to keep running. any ideas what it could be. friends tell me to buy a new carburator. thanks.
Old Mar 20, 2002 | 06:48 PM
Wilber15's Avatar
Wilber15
running rough
Pull the Carb apart and clean it with carb. spray. U might also want to adjust the jets and idle screws. Spray carb spray around different parts of the engine where you have gaskets to, and listen for it to change idle speed. this indicates a gasket leak. u might want to change plugs too and see how bad they are..i changed mine recently, and it helped my 302 efi. U problably won't need a new carb., just clean it. It might also be a bad EGR?? i don't know much about EGR controls, but i've seen them cause rough idles and stuff in vehicles. hope that helps..laters
Old Mar 23, 2002 | 10:45 AM
rcdague's Avatar
rcdague
running rough
I have an 83 that does the same thing. After a lot of frustration I did narrow it down to the carb. I have not taken mine apart yet, but will soon. Getting the whole carb clean will help a lot. The rebuild kit is only $40, a lot better than the price of new carb. You may just need to get the jets and power valve good and clean.
Old Mar 23, 2002 | 12:03 PM
tmh's Avatar
tmh
running rough
02xlt3.0
1983 - 2012 Ranger & B-Series
Aug 7, 2013 05:57 AM
Junior81
Apr 20, 2013 05:24 PM
allingeneral
Dec 3, 2011 07:25 PM
mackdog
Jan 11, 2010 06:37 PM
fordman_peoriahghts
Aug 29, 2008 04:18 AM
