V10 Excursion into V8 Ex
Old Feb 8, 2005 | 12:34 PM
UKSuperduty's Avatar
UKSuperduty
Have the chance to buy a V10 Chassis but the engine has no air intake/radiator or brain(ECU) what would I need to transfer into my V8 Excursion?
Old Feb 8, 2005 | 01:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
Intakes are the same (virtually).
You'll need a radiator...although you should check to see if you can use yours and your'll need an ECU.
That's it! Everything else goes right in!
May I suggest that you throw some headers on it before you drop it in? The V10 really could use them and they are a pain to install once the engine is in. A Port and polish wouldn't hurt either...
Old Feb 8, 2005 | 01:09 PM
UKSuperduty
Is my ECU no good for the V10 then?. I think the radiators are the same....any ideas on where to get an ECU for the vehicle?, Do you mean port and polish the heads ? to what benefit? if you search the following # at ebay then you will see the donor.
item # 4526240381.
Any comments would be appreciated
Thanks
UKSD
Old Feb 9, 2005 | 02:16 AM
AlfredB1979's Avatar
AlfredB1979
The v10 is the v8 plus two more cylinder, so other than length specific parts, the engine will obviously drop right in, being a factory option for the Explosion. The radiator ought to be the same. Like Ford can afford to make mulitiple SD platform radiators for what is the same engine family.
Need computer (car-part.com) and engine harness, I believe. Might need to move the mounts up a smidge, too.
Old Feb 10, 2005 | 11:44 PM
Matts72's Avatar
Matts72
Actually, call around to a few parts stores in your area and see if you can have the ECU flashed. You'll need to find a VIN code for a V10 powered truck, the ECUs are the same, just the V10 compy is programmed to monitor two more cylinders.
Eric H
Vehicles for Sale
Dec 1, 2014 01:34 PM
MUSKRATT2
Aug 15, 2012 02:55 PM
driller tom
Modular V10 (6.8l)
Apr 11, 2010 07:26 PM
cbradford
Modular V10 (6.8l)
Sep 12, 2008 08:36 PM
billb
Nov 26, 2001 10:18 AM
