Cant get codes-need definitive answer
Old Feb 22, 2005 | 05:39 PM
Bigted's Avatar
Bigted
Originally Posted by threewaters
You may want to track your ECM ground. My 85 4.9 has a separate ground attached to the negative post. The connector near the post was bad and that caused a battery drain and the ECM went inoperative. But you are not mentioning a battery drain in your thread.
Folks I finally got all the answers I was looking for. I don't mean to be a tease but I gotta go. I will post in detail manana. All you guys rock.
Old Mar 5, 2005 | 12:48 AM
Brian BJ's Avatar
Brian BJ
Bigted:
How is your rig doing? Please share the details of what you found as I've had the same problems.....
Thanks,
Brian BJ
Old Mar 5, 2005 | 02:36 AM
85F_150driver's Avatar
85F_150driver
i have same problem also but i am going to solve it by switching to the duraspark ignition system soon. Simpler and lots less wires. make sure your fuseable link is good and that it is well grounded and other things mentioned above.
