I run the transmission in OD all the time, except when towing or loaded. I them select the OD off on the shift lever and use direct drive. I have never noticed any "hunting gears" and have 240,600 + on the transmission. The AOD is another issue and has D as a selection and is 3rd gear or direct drive. It may be that the torque from the 460 in it's operating range really compliments the E4OD, I don't know, I just know it works for me.
I tried this OD trick on my 351 93EB and it seemed like it was in 4x4 like the way when I let off the gas I kinda got lunged out of my seat a little like it was down shifting. It did it every time at speeds around 30 to 40 mph. I am all for better performance and gas mileage but this didnt seem right.
i have a 91 with a AOD, and i use the overdrive button and the lower gears to slow down. i also use the od button to turn the od off on back roads, but i mostly just leave it on.....personally....i the automatic tranny. i sold my f150 with a 5 speed, cause i needed a 4x4, and go the bronco....and im still looking for the shifter sometimes.
If your O/D has a button then it is an E4OD, not an AOD.
I'm with RRobben and JBronco. The only time that I don't use OD is when pulling a heavy load. As for tranny lifespan, we had an 85 F150 w/ AOD and 302 and that truck has gone through 2 motors and is still pulling strong today with the original transmission. I can not remember many times when my Dad manually shifted it to Drive and I know my mom never took it out of OD. The truck has 247,000 kms on it.
The more that I think about it, the more absurd that I find this thread to be. You are supposed to put your truck in "D" and drive it. With the OD on. That is how it was designed. It's ridiculous to keep turning the OD off for all sorts of imagined reasons. The only reason to turn it off is when pulling a trailer, and I hardly even do that. I pulled trailers for thousands of miles with the OD on. The only time I have turned the OD off, with or without a trailer, is when going up an incline and I needed a lower gear; or when going down a long decline with a trailer, to keep the trailer from "pushing" the truck.
My transmission is 15 years old and works fine. Even if it were to break tomorrow, I still would not change the way that I use it. I can handle a rebuild every fifteen years; but I am sure that my tranny will last quite a bit longer anyway.
JBronco, I understand your frustration. The only reason I lock out the overdrive when towing the gooseneck is that I started doing it that way and loaded it maxes out my capacity. I pull nearly every weekend. Occasionally I have to get cement blocks to a customer and we don't have a flatbed going that way. I load her to the helpers and generally take it out of overdrive then also. Other than that I put the E4OD in Drive (overdrive also) and let her roll. Never had a problem.
No need to get upset over it. I am talkng about the AOD, not the E4OD. Like I said, I am not sure how the E4OD works but it is not good to drive the AOD in O/D if you are going under 55 or so. The AOD was one of Ford's first attempts with over-drive and it shifted in way too early. The AOD has an O/D band and it will burn up faster if you are in overdrive at low RPM's. As I pointed out before, that is why a vehicle with an AOD has a column that reads P R N OD D 1. The D stands for Drive. You should not, and I repeat should not pull a heavy trailor with O/D on unless you are coasting downhill. Nothing will burn up your tranny quicker. My original owners manual specifically states that, On vehicles equipped with automatic overdrive transmissions, trailer towing, particularly in hilly areas and with heavier trailors, may cause excessive shifting between overdrive and third gears. Moving the selector to D(overdrive lockout) will eliminate this condition. If you go and talk to a Ford tech that has been around for a while and knows his trannys, he will tell you the same thing. Maxt, the original poster said that he had an AOD, so that is why I have been giving him tips on the AOD, NOT THE E4OD.
I'm sorry kameronth, I did not mean to give the impression that I was upset. I rarely get upset about material things in general, and certainly not about a web page discussion about transmissions. And I definitely do not know the difference in wear of the O/D between AOD and E4OD. So please excuse my ignorance on the subject.
As far as the trailer issue, I am well aware about the recommendations for towing. However, if I am towing on the freeway for a long distance, and the truck is doing 65-75, I still have it in OD because it is far removed from the speed where it would hunt between D and OD. In that case, though, I still switch the OD off when going up even the slightest incline.
I agree with you JBronco. I was chatting with a buddy at work about this issue and he says to me...isn't that what the auto transmission is supposed to do? Shift for you so that you don't have to like in a manual. The truck decides when it needs to drop a gear and when it wants to go up a gear. That's the whole point of *Automatic* transmissions....
For some other reassons I did some research on auto trannies, and some of the earlier units had narrower OD bands, and that can explain why those trannies were prone to failure in OD under load, and at the same time it can also explain their bad reputation. I think it was with the AOD that one change by Ford was to replace 1.5" OD band with 2.0" from one year to the next.
In any case, I think under normal use there's hardly ever a need to turn off the OD. Towing, and gear hunting on very steep terrain are the two main exceptions I can think of right now that could necessitate turning off OD. I can go up to Snoqualmie pass (western WA, I-90) in OD all the way, but can't do the same on the hill at Washtucna. (eastern WA, SR26)
