Sagging Driver's Door
Old Feb 8, 2005 | 12:03 AM
mike jaguar's Avatar
mike jaguar
87 Ranger - The driver's door drops about an inch when it's opened and it's hard to close without lifting it into place. The door hinges appear shot. Who is a source for a repair kit and what do I ask for? Thanks/Mike
Old Feb 8, 2005 | 05:50 AM
Dan Robertson's Avatar
Dan Robertson
Years ago, (I'm dating myself) Ford used to sell a bushing kit. The pin in the hinge was removable. All that you had to do was support the open door, drive the pin out, install new bushings and put the pin back in. I believe that now you would have to buy the entire hinge.
Old Feb 8, 2005 | 04:32 PM
ol yeller's Avatar
ol yeller
bet you could find those bushings at a bearing shop. all they need is od and id.
Old Feb 9, 2005 | 06:10 AM
Dan Robertson
A person could, but I dont think that the hinges are built to be taken apart. The older vehicles had removable hinge pins. Some of the newer vehicles have a head on both ends of the pin. You would probably end up grinding one end or the other to get the pin out. I had a small Chevrolet car once that had the entire hinge welded in place. You had to grind the head off one side of the pin and drive it out to remove the door.
