1978 - 1996 Big Bronco
engine running hot
Old Feb 7, 2005 | 09:33 PM
xKirkx's Avatar
xKirkx
Exclamation engine running hot
i was driving on the freeway and i put my truck in overdrive to go up a slightly steep hill. when i took it off i noticed that my truck was running hot. so i turned on the heater but it was blowing out cold air even after having it on for five minutes it was still cold when my engine was reading hot? when i got home i popped the hood and noticed around the coolant reservour coolant was everywhere. so i was wondering what the problem might be? i checked the thermostat and it is working fine.
Old Feb 7, 2005 | 10:49 PM
xKirkx's Avatar
xKirkx
i found out it was my waterpump so i guess nevermind
Old Feb 8, 2005 | 09:41 AM
Kemicalburns's Avatar
Kemicalburns
also you should not use overdrive when climbing. its not good for your tranny. I would also put a new tstat in along with your water pump. its just good insurance.
Old Feb 8, 2005 | 07:37 PM
BigRedBronc's Avatar
BigRedBronc
Yup, what KB said.
Old Feb 8, 2005 | 09:49 PM
xKirkx's Avatar
xKirkx
oops i meant i took it out of OD. i always say that cause you push the button so i think of it as turning it on, but ya i turned it off.
