Backup Light Problems
Old Feb 7, 2005 | 08:38 PM
dezire1068's Avatar
dezire1068
I've got a 94 Ranger that is having backup light troubles. I just had the transmission replaced and it's running fine...however, someone told me that my backup lights where on while I was in drive. I checked it out and the backup lights stay on in all gears other than park. Any ideas as to what the problem could be? Thanks
Old Feb 8, 2005 | 02:59 PM
Dealford's Avatar
Dealford
Welcome to FTE !
The switch has probably shorted out inside.
AL.
Old Feb 8, 2005 | 03:05 PM
dezire1068's Avatar
dezire1068
Inside what? Are you referring to the neutral safety switch??? Thanks!
Old Feb 8, 2005 | 03:11 PM
Dave257's Avatar
Dave257
There is a switch that turns the lights on when you are in reverse. It sounds like it is defective or maladjusted. The shop that changed the transmisssion should check it for you.
Dave
Old Feb 8, 2005 | 03:16 PM
Dealford's Avatar
Dealford
You said that the reverse light were on in drive which translates to an automatic tranny which translates to neutral saftey switch. The reverse light switch on a manual tranny is only for the reverse lights & is a very simple switch.
AL.
