1978 - 1996 Big Bronco
C6 shifting question
Old Feb 7, 2005 | 05:07 PM
poffutt's Avatar
poffutt
89 bronco 351 c6 33X12.5x15
since I only have the 3 gears... I was wandering if they are shiffting correctly.
If I am going 40 mph and floor it, the trans will downshift into 2nd. Once I go over 40 mph and floor It, it will not down shift. The RPMS are only at 2500 and it does not have enough rpms to pass . If I mannualy do it, it feels right! it jumps up to about 3000 rpm and takes off. Next example. If I floor it and let the truck run through all 3 gears. It changes gears at about 3900 rpm. Shouldn't it go higher than that? If so what should I do?
Old Feb 7, 2005 | 05:25 PM
Mudrover06's Avatar
Mudrover06
i also have a c6 tranny, it shifts with it floored at about 4500 rpms and mine shifts down to 1st when doing 40 and yours probably does to
Old Feb 7, 2005 | 09:05 PM
SoCalDesertRider's Avatar
SoCalDesertRider
It doens't sound like it's having a problem. You can adjust when it shifts by turning the modulator adj screw. Clockwise for later, counterclockwise for earlier. The adjustment screw is inside the vacuum inlet on the modulator on the right side of the tranny. Also, check your throttle linkage. Mine was not reaching full throttle and the trans didn't want to downshift because the carpet was keeping the pedal from going all the way down. I bent the linkage a little it works great .
EDsurvivor
20
Oct 13, 2021 02:41 PM
2gumby2
2015 - 2020 F150
Jul 23, 2016 08:26 AM
JoshGriffith
All Things Towing
Feb 23, 2016 05:39 PM
scottskingdom
Dec 19, 2003 10:30 AM
MustangGT221
37
Mar 28, 2003 01:16 PM
