Quick question about driveshafts????
Old Mar 31, 2002 | 10:21 AM
Tetchy101's Avatar
Tetchy101
What kind of lubricant or grease can I use on my splines so as to not contaminate my tranny fluid. Or does anyone have another quick fix to the clunk I hear when I shift from drive to reverse and vice-versa. Does my 351 have that much torque on my C6 and NP208 transfer case???
Timmy T
Old Mar 31, 2002 | 02:43 PM
1w_racer's Avatar
1w_racer
Did you check the u joints those are usually the culprits of those clunks in trucks?
Old Mar 31, 2002 | 03:07 PM
Tetchy101's Avatar
Tetchy101
U-Joints are tight. Could it still be them for any other reason????? Im thinking its just the way the Ford Gods made it.
Tim
Old Apr 1, 2002 | 06:27 PM
1w_racer's Avatar
1w_racer
[updated:LAST EDITED ON 01-Apr-02 AT 07:29 PM (EST)]If you are absolutly sure the u-joints are tight then I dont know. It could be in the rear end also. So more than likely it will be a big job if its internal.
I think u can use about any type of grease.
jon
Old Apr 1, 2002 | 09:15 PM
Mil1ion's Avatar
Mil1ion
Old Apr 1, 2002 | 09:25 PM
Franklin2's Avatar
Franklin2
If you have the yoke and splines that go into the transfer case, then don't grease it because it is lubed internally by the transfer case lube. My 1980 has the splines that are external to the transfer case and it also has a grease fitting. This setup gets the grease. When you are checking for play, jack up the rear wheels and put the tranny in neutral to take any pressure off the driveline.
Old Apr 1, 2002 | 11:02 PM
Mil1ion's Avatar
Mil1ion
I use high temp disc barke wheel bearing grease on my driveshaft splines.It works great.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/Mil1ion.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
