Sponsored by: Kumho
rim size??
Old Feb 7, 2005 | 07:38 AM
marilyn's Avatar
marilyn
rim size??
my 66 f100 had 14 inch rims if i go to the junkyard and get modern 15 inch rims will they have the same 4.5 on 5 bolt pattern as the 14s.I want to use my old drums.
Old Feb 7, 2005 | 11:29 AM
73Custom's Avatar
73Custom
I thought all 1/2 tons up to '96 had 5 on 5.5 pattern. Does your 66 have the stock axles? If it is the stock 5 on 5.5 pattern - get rims from any F100/F150 or Bronco up through '96 and they will fit fine. Remeasure your pattern - or take a rim with you to the salvage yard...
Marty
