Hi everyone
I have a 1992 Ford Ranger XLT extra cab 2 wd with frame damage. I also have a 1987 ranger XLT 4wd donor frame. I was wondering if I can strip the suspension out of the 4wd frame add my 2wd suspension and reassemble truck with my 2wd parts? I just need to know if these frames are interchangeable without any welding. I know it's a lot of work but my 2wd truck is too good to junk. Any responses or suggestions would be greatly appreciated.
hi everyone; i have a tech question. i have a 1992 ranger 2wd extra cab with frame damage, and a 1987 ranger 4x4 extra cab frame i want to use as a donor frame for my 2wd truck my question is; can i use the 4x4 frame if i strip all the parts out of it and can i just bolt in my 2wd suspension and 4.0 engine or are the frames different on 2wd and 4wd rangers? any advice would be greatly appreciated!!
Start off by comparing the wheelbase measurements & cab mount locations.
What are the engine/trannys in the 2 trucks? Lots of guys prefer to go to 4x4.
AL.
