Turn signals will work for maybe 7-10 "tries" then will blow the fuse (no matter how large a fuse I use). Hazards and breaks work just fine. However, when I put my foot on the break while the hazards are on, the hazards no longer work. The back lights all go "off" until I take my foot off the break again.
So, I have tried a number of times to replace fuses, but they all blow. Since the same fuse powers the back-up-lights, I also loose these each time. Any thoughts? The truck is old and salty, so I could see why this would a be a shorting problem.
...Welcome Michael, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Thank you for those suggestions. I was afraid to have to look into the multi-function switch... getting the steering column off can be a pain. I do have a wiring harness as well. How do you know if it is the cause of the problem? I don't have a trailor...
Like Ken sez, read your manual. When I had to change the ignition switch on my 87 I simply followed the directions in my Haynes manual for removing the plastic trim around the steering column & changing the switch was a very simple 30 minute job.
When I had to change the multifunction/turn signal switch on my 95 Taurus i simply followed the directions in my Haynes manual for removing the plastic trim around the steering column & changing that switch was also a very simple 30 minute job.
BTW your hazard & turn signals use the same wiring & bulbs, so it does sound like you need to replace the multifunction switch.
