how many are using the volare type front end
on
1 Post
I had a volare to put in my truck, but wasn't too comfortable cutting that much of the frame or making that big of spacers to keep from cutting the frame. But I did ride in a few F-1's that a guy around here did, put Volare clips in all 3 of the ones he built(his, his daughter's, and his son's) and they rode nice, and they have the benefit of the adjustment in height.
Originally Posted by bcarlson
"Only issue you may not solve is the fast steering. May or may not bother you."
Would changing the size of the power steering pump pulley help this out? Just thinking out loud...
Ben
Ben
Sam
Originally Posted by xfordman
I used the matching Volare pump and the steering is perfect.
The Volare is an OK setup, but not the best IMO. I would go with something a bit more beefier if I was to do it over again. The Dakota kits seem the way to go now. Better yet, I have a Mechanical Engineering freind of mine that would jump at the chance to design me a front end...we have discussed it more than once
Volare clip
I've started tearing down the clip I got out of a Diplomat, and I'm trying to figure out how to get the little vibration dampner/pivot box off the steering box? It's about five inches long, and maybe 3 inches in diameter... and is mounted right on the end of the shaft coming out of the steering box.
Also, I am wondering how to disassemble the upper and lower ball joints?
Any ideas?
Thanks,
Ben
Any ideas?
Thanks,
Ben
on
Look for a rolled pin you have to drive out....the lower ball joints in mine had just been replaced but I had to replace the uppers. There is a special tool you need to unscrew them. I took mine to NAPA and had it done. Even they didn't have the special tool and ordered one to do my job.
Vern
Vern
#28
Any ideas?
Thanks,
Ben
Any ideas?
Thanks,
Ben
for the ball joints.. there is a special press tool, you can rent for free at Autozone, or buy at Harbor Freight. item 38335, on sale now for $19.99
Sam
#29
