what would make the power sterring work only in one direction.
turns fine to the left,will not turn to the right.jack front wheels off the ground & it works both ways.Both wheels will turn both ways if you grab them & turn them by hand.makes no sense.Thanks for any help
SeaEra...
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
