Which diameter is it ?
Old Feb 5, 2005 | 09:59 PM
KSever's Avatar
KSever
Question Which diameter is it ?
Picked up this 89 F-250 4x4 Heavy Duty last week with a straight 6, 5 speed/OD, and a snowplow for $350. Has a little rust not much but the clutch is burned. I've been looking at all the internet parts suppliers and I always get this option of which size 10" or 11". How do I know which one I have without tearing out the clutch to find out?
Old Feb 6, 2005 | 09:23 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 6, 2005 | 10:36 AM
KSever's Avatar
KSever
Tim,
Thanks for the warm welcome! And after looking better I guess I should have posted this in Performance related.
I am new to this Ford truck thing since I have been a Chevy truck man all my adult life, Still have the 63 Chevy truck that I'm rebuilding in the garage but I came across this 89 Ford 4x4 by chance,cheap, and I couldn't pass it up. Maybe I'll become a convert.
Old Feb 6, 2005 | 11:03 AM
ford4.9's Avatar
ford4.9
Smile
ksever, they will both work. the 11 will need different bolts for clearance which the supplier of the clutch should give you. If they do not, do a search for LUK clutchs and they have the bolt size listed that you will need. hope this helps
Old Feb 7, 2005 | 12:50 PM
aguylookingforadvice's Avatar
I have an 89 4X4 4.9L just replaced the clutch. I bought a heavy duty LUK 11" - I will save you a headache. When the tranny was pulled off we learned that the stock disc/pressure plate were 10". As ford4.9 indicated you will need bolts for the 11" disc/pressure plate. I bought my clutch kit from dial-a-clutch.com and they forgot to send me the bolts for the 11" set. Luckily, we had some extra bolts available but it set us back a day or so..good luck!
Old Feb 7, 2005 | 04:36 PM
KSever's Avatar
KSever
Thanks Guys for all the info, I'm going to look into it and see what happens. I haven't got the truck home yet so hopefully it doesn't need a clutch.
Sure helps when you find a good website like this with all this good feedback so fast.
