Sponsored by: Real Truck
Need help passing emissions
Old May 22, 2008 | 02:13 AM
jaynalbu's Avatar
jaynalbu
I have a 97 F350 5.8ltr and fail the emissions horribly, according to the tech doing the test. I asked what would make my results so high. I don't remember the readings but they were the highest he had seen in years. Great. He wanted to hook up some computer terminal that would have told me right away what the problem was but the 97 F350 did not have this option. Any suggestions as to where to start?
Thanks
Jason
Old May 22, 2008 | 07:19 AM
99f350sd's Avatar
99f350sd
First is your CE light on. Does the bulb check work? If its that bad you should have a light on. O2 sensors are prob bad.. Get a scanner to check don't guess its too expensive..
Dick
Old May 22, 2008 | 01:41 PM
jaynalbu's Avatar
jaynalbu
No CE light. And I don't have or can't find the place to plug in to the computer.
Thanks for your reply.
Jason
Old May 22, 2008 | 02:29 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Do you have a catalytic converter and does it still have it's innards?
Sounds like they did a sniffer test, and you failed based on the limits.
Gotta post the limits, what you tested at, and maybe we can come up with something.
START YOUR OWN THREAD!
Old May 22, 2008 | 02:32 PM
jaynalbu's Avatar
jaynalbu
Yes it was the sniffer. I don't have the results but I do know they were like hundreds over what was allowed. I may go getanother print out from them.
Jason
Old May 22, 2008 | 02:39 PM
krewat's Avatar
krewat
Jason
Sounds like the HC (hydrocarbons). Either running rich (injector stuck open or leaking, bad fuel regulator diaphragm or vacuum connection to the regulator (so it goes to 40lbs pressure all the time including idle), or a bad cat.
But even with a cat that's not doing anything, it shouldn't be much more than 250-300 HC's
Gotta get a printout, give us numbers, and again, start your own thread
Old May 22, 2008 | 02:40 PM
krewat's Avatar
krewat
Or even a bad temperature sensor making the engine run rich when warmed up.
Livadia
198
Apr 19, 2019 09:13 PM
xmntncopper
2009 - 2014 F150
27
May 11, 2013 09:51 PM
D8chumley
2009 - 2014 F150
20
Apr 28, 2013 06:56 AM
cougarman001
Texas Chapter
Jan 8, 2012 11:15 AM
Pejeeper
Escape & Escape Hybrid
17
Sep 28, 2007 12:52 PM
