Transfer case linkage/engagment/indicator lights
Old Feb 5, 2005 | 07:45 PM
Caper10's Avatar
Caper10
I have a 1993 F150 4X4 4.9L automatic with manual Xfer case. I removed the shifter and linkage from the transfer case to free it up. I was having trouble engaging into 4H, it would pop out. I also could not get the transfer case into N or 4L. The linkage was fairly rusty and I managed to break off one of the bolts holding the shifter to the linkage, after drilling i broke off a tap in the hole, i am going to have to replace. My question is, with the linkage disconnected, the lever on the transfer case seems go only into 2 positions. Is this how it is suppose to be that way? I thought I should be able to move it from 2H-4H-N-4L. Also related I have no indication on the dash lights as to what position the transfer case is in. I only hjave this truck for about a month, and the transfer case position lights have never worked. Appriciate any help.
Thanks
