holley 600
Old Feb 5, 2005 | 04:21 PM
openscars's Avatar
openscars
holley 600
Does anyone have a diagram for a holley 600? i just need to figure out where all the vacuum lines and everything else hooks up. thanks!
Old Feb 5, 2005 | 09:42 PM
lee's Avatar
lee
Hi,
First off which model Holley do you have and what model truck is it going on?
If you have power brakes you want to connect the Vac booster line to a part that gives you manifold vacuum. Same thing for a PCV. You may need a "T" to tie both to the same port.
Most folks connect the Vac advance line to the "timed" port on the carb. This is the port that is on the passenger side of the carb, near the front, sticking straight out to the side.
Hope this helps,
Lee
Old Feb 6, 2005 | 12:19 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Brake booster vacuum and pvc vacuum
If you "TEE" the booster brake vacuum with the pvc line your vacuum signal to the booster will be less. Brake boost may be less (harder pedal). Better to have the booster by itself and and the pvc by itself also.
Carl....=o&o>....
Old Feb 6, 2005 | 08:26 AM
openscars's Avatar
openscars
i have the holley for motorcraft. its going on a 79 bronco.
