Sponsored by: Auxito
engine knocks ???
Old Feb 5, 2005 | 03:01 PM
jtextripp's Avatar
jtextripp
Question engine knocks ???
I have an 1997f150 with a 4.2l v-6, it hadn't been started in a couple of months(nov-dec,ok..and jan) I started it and a loud knocking sound is coming from the front of the engine....Any ideas on this and how to fix it??? It never made this sound before. A friend said something about a lifter or something stuck????
Old Feb 5, 2005 | 03:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Old Feb 6, 2005 | 01:27 PM
jtextripp's Avatar
jtextripp
hey tim,
it's jtextripp, I didn't realize I needed to stick around, how long to get responses???
Old Feb 6, 2005 | 01:56 PM
IB Tim's Avatar
IB Tim
Well Sunday afternoon...and SuperBowl Sunday....could be a bit slow.....
Hang in there
Old Feb 7, 2005 | 12:28 AM
Racerguy's Avatar
Racerguy
How many miles on your truck?
How long have you let it run now after having sat for so long?
Does the oil look clean? Is the coolant level down at all?
Old Feb 8, 2005 | 06:02 PM
jtextripp's Avatar
jtextripp
150k, let it run for 30min, tried an engine flush(5min), changed the spark plugs but no change in the knock. I do remember it tried to miss when I first started it....
Old Feb 8, 2005 | 11:07 PM
Racerguy's Avatar
Racerguy
You might also try asking in the 4.2 forum which is a ways further down on the main forum page.
Noises can be hard to diagnose in real and almost impossible on here but someone there might have some more ideas for you.
