6.9 hard starting [help]
Old Feb 4, 2005 | 07:29 PM
angelmat4's Avatar
angelmat4
Unhappy 6.9 hard starting [help]
I Have An 85- 6.9 I Have Replaced All Of The Glow Plugs I Put The Pump In Time With Engine [ The Mark On The Bolt Flange With The Mark On The Housing ] But Same Problem In Morning I Use The Glow Plugs For 1.5- 2 Min Will Not Start Must Use Starting Fluid Starts RIGHT Up. Let It Warm Up And You CanT Release The Key Quick Enough Starts Right Up. But Let It SIT 1/2 Hour Or Longer Must Use Starting Fluid To Start When Running It Sound Great Idles Smooth I Just Bought Truck It Was Warm When We Went To See And Test Drive Can Anyone One Tell Me Where To Start Trouble Shooting It [help ]
Thanks
Angelo
Old Feb 4, 2005 | 08:34 PM
PLC7.3's Avatar
PLC7.3
Do you have a push button for the GPs.
Old Feb 5, 2005 | 07:52 AM
angelmat4's Avatar
angelmat4
thank for getting back to me plc7.3 no we are shorting out to solenoid with power behind battery just found out where controller is on driver side head will have to order one or junk yard it today but for today or untill it comes in. will hook up push button today think the same way power to solenoid
angelo
Old Feb 5, 2005 | 08:41 AM
pnose's Avatar
pnose
Angelo
You should check those new glo plugs as 1.5-2mins is way too long(unless you used constant duty plugs).On the coldest day they should only be on for 12-15 seconds.I think you may have burned up the gp's.What brand plug did you use,motorcraft/beru i hope,(btw these are not constant duty)if not you may as well replace them again.
Old Feb 5, 2005 | 12:09 PM
angelmat4's Avatar
angelmat4
ok i ck plugs are ok were just put in on thursday but ck with test light there good will ony use 10 to 15 second spurts little time in between
thanks
Old Feb 5, 2005 | 05:48 PM
angelmat4's Avatar
angelmat4
still same problem no start with out starting fluid
Old Feb 5, 2005 | 08:36 PM
toyrobotus's Avatar
toyrobotus
Exclamation whoa
You have to stop shooting starting fluid in the engine...especially if you have been cooking the GP's for that long. I think you may have a fuel delivery problem....but try using wd-40 instead of the ether so you dont blow yourself up.
Old Feb 5, 2005 | 11:55 PM
PLC7.3's Avatar
PLC7.3
Try doing the setup on Ziggster's web page....... use your pushbutton instead of a toggle switch safer.........
http://www.members.shaw.ca/k2pilot/
