trans making weird noise
Old Feb 4, 2005 | 06:30 PM
fordtrck302's Avatar
fordtrck302
HEy there got a weird problem i just noticed i own a 1995 f-150 4x4 witht he mazda 5 speed, i just put a remanufactued one in last april, it now has about 15k miles on it i dont know why but i had it in neutral and i reved the engine when it got to about 2300 and above it made this weird noise like a somthin metal was spinning kinda like when you turn on a bench grinder now all my gears work fine they all go in gear and stay in gear, any thouts on what it might be, i have a 1 year warrenty unlimited miles in the trans so if its goin id like to know. also i noticed wen i have it in reverse and i have to put a lot of stress on it like to pull someone out of a ditch it makes a grinding noise a different one, But it doesnt do this on normal reverse only when i try and pull soeone out or give it a lot of gas while realesing the clutch, whats that all about, well any thought would be awesome thanks alot
Old Feb 7, 2005 | 12:57 PM
aguylookingforadvice's Avatar
I have a similar noise and the same tranny. A bunch of folks told me that it's the Input Shaft Bearing within the tranny. It runs fine, it just makes a loud, noisy, "whirling sound". The responses that I received didn't sound too promising. Good luck.
Old Feb 7, 2005 | 03:09 PM
DcSkater602's Avatar
DcSkater602
you sure the noise is coming from the trans??? Ive heard similar sounds but i was motor noise not trans... does it do it once the motor is warmed up or cold or aall the time..
Old Feb 7, 2005 | 05:37 PM
fordtrck302
ill have to check i know the sound from reverse is any time warm or cold but ill check on the other noise thanks
